PackGernertaor error
nimaltd
I can not open my project after update cubeMX to latest version.
Semer CHERNI
Hello @nimaltd
After verification I was able to see the error.
The case was escalated internally for analysis and fix 167308 (this is an internal ticket number).
In the meanwhile, you can use the pack creator from the CubeMX 6.9.2 as a temporary solution.
KR,
Semer.
6 REPLIES 6
Why not? What happens when you try?
cubeMx works well. only packet generator does not work. nothing happen. only wait after open project.
I have tried with 2 pc. Both of them have the same problem.
Semer CHERNI
Hello @nimaltd
First let me thank you for posting.
Could you describe the scenario which show this behavior.
Could you share the Cubemx log for that you can start the tool with command line.
KR,
Semer.
Hello. This is not cubeMx error. Only in Stm32packCreator.
I can not open my previes project and can not use https://github.com/nimaltd/STM32-PACK/blob/main/SPIF/NimaLTD.I-CUBE-SPIF.2.0.1.pack for create a new project.
It was generated before update cubemx.
Semer CHERNI
Hello @nimaltd
KR,
Semer.
