CubeMX code for Nucleo32 L432KC does not build
Paul Mellor
Posted on July 04, 2017 at 18:33
Repro steps...
  • Create a new CubeMX project, selecting the Nucleo32 L432KC board.
  • In settings give it a name and select to generate code for the 'System Workbench for STM32' selecting SW4STM32
  • Generate the code and open the project.
  • The project does not build.
The problem is that core_cm4.h cannot be found - its not present.
Can anyone help?
Paul
#nucleo-l432kc #cubemx #sw4stm32
john doe
Lead
Posted on July 05, 2017 at 04:56
while you omit such information from your post, did you try to upgrade anything lately? which version of cube is your repository?
remove the 1.8.0 and 1.8.1 directories and zip files and let it download and patch them again. thats what worked for me.
Imen.D
Posted on July 05, 2017 at 10:06
Hi
Mellor.Paul
Make sure that the include paths configured properly into the project from the correct directories.
For more help on this issue, please share your .ioc file and provide more details about the tools (Cubex, SW4STM32) version you have used.
Imen
Imen
