CubeMX bug: Can't set H5 clock speed to 250 MHz (eg. H562IITx)
"Frequency searched for is out or range."
‎2023-05-03 1:55 AM
‎2023-05-03 2:17 AM - edited ‎2023-11-20 6:39 AM
Hello @Community member​ ,
I couldn't reproduce this issue :
Foued
Foued
‎2023-05-03 2:35 AM
ok thank you for the hint, but shouldn't the "resolve" solve that?
Uwe
‎2023-05-03 2:40 AM
You may choose the right combination to reach 250MHz.
- PLL1 source Mux : HSI
- System Clock Mux : PLLCLK
‎2023-05-08 1:44 AM
some pre-configured interfaces (import from old MCU) limit the max frequency to 200 MHz.
We are working it, but thank you for the hint.
Uwe
‎2023-05-08 2:28 AM
If this solves your problem, please mark my answer as "Best Answer" by clicking on the "Select as Best" button, this can be helpful for Community users to find this solution faster.
Foued
