Configuration of SDMMC peripheral in CubeMX
‎2023-03-08 3:43 AM
I am trying to connect to the WFM200 wifi module over SDIO. I am using the SDMM peripheral library/code for this.
However, in the selection in CubeMX there is only the options for SD and MMC but no SDIO.
Which option should I choose for using SDIO with the WFM200?
- Labels:
SDIO-SDMMC
STM32CubeMX
STM32H7 Series
‎2023-04-13 10:22 AM - edited ‎2023-11-20 7:21 AM
Hello @Hueli.1​,
Here is an example to configure SDIO. You may need to increase the SDIOCLK divide factor if getting FR_DISK_ERROR
Hope this helps!
Hello @Hueli.1​,
Hope this helps!
‎2023-04-13 11:30 PM - edited ‎2023-11-20 7:21 AM
thank you for the answer.
I now went with low gpio speed also to reduce noise in the signal since I am using a nucleo allowing only speeds up to ca 400kHz without distorision:
