code generated with cubeMX 6.1.0 and above for udp ethernet ping
ramsita
Hello ,, can anyone share the code for  generated with cubeMX version 6.1.0 and above.  ethernet with udp  pinging works code . the code should able to run in keil... thanks.....
1 REPLY 1
Imen.D
Hello @ramsita ,
There is no .ioc files (ready for use project) with CubeMX.
Ready-to-use UDP applications running in keil can be found in the STM32CubeH7 MCU package:
STM32CubeH7/Projects/NUCLEO-H723ZG/Applications/LwIP/LwIP_UDP_Echo_Server at master · STMicroelectronics/STM32CubeH7 · GitHub
STM32CubeH7/Projects/STM32H743I-EVAL/Applications/LwIP at master · STMicroelectronics/STM32CubeH7 · GitHub
This ST wiki page may help you to create project from scratch:
How to create project for STM32H7 with Ethernet an... - STMicroelectronics Community
Imen
