Unable to select SRC PDO
RJain.1
I am using a custom board based on STM32G4. I have successfully generated SINK code using cubemx and testing it using UCPDcube monitor. Explicit contract has done correctly but unable to select a source PDO.
PFA, trace, and screenshot.
I appreciate any help you can provide.
@FBL , Can you please check
FBL
Hi @RJain.1
Did you check the demo provided here.
It appears that the issue lies in the implementation of the USBPD_DPM_SNK_EvaluateCapabilities()function. This function is crucial for selecting the appropriate Source PDO.
Best regards,
FBL
