Cannot initialize ADC1 in STM32G071RB on EWARM
2020-10-01 11:58 PM
I'm debugging STM32G071RB by using Nucle-G071.
The code I use is generated by STM32CubeMX, and I try to put break point to variable in "static void MX_ADC1_Init" but it semms like not to initialize because I cannot put break point there.
I confirmed that sample code in L0 is fine without any trouble.
I only generated initial code and never write user code.
Does anyone find this problem before?
If you have any advice please teach me, thank you.
ADC
DEBUG
IAR
STM32CubeMX
STM32G0 Series
2020-10-21 3:45 AM
Hi Nesrine.JLASSI (ST Employee)
Thanks for your comment.
I have already figured this out.
This problem is coming from setting of develop environment (EWARM).
"Optimization level" was in the highest level. This is why I could not put break point.
Thank for your cooperation
Best regards,
Hayato EHATA
2020-10-21 3:25 AM
Hi @HEhat.1
Thanks for the feedback, i did the same scenario and i had no issue. So, could you please share your .ioc file to check with.
Best regards,
Nesrine
2020-10-21 3:45 AM
Best regards,
Hayato EHATA
