Both CubeMX executable and App missing from Window Start but CubeMX available inside CubeIDE
‎2025-04-09 6:04 PM
I am installing VS Code with the STM32 extension. In the settings I need to provide a path to the MX executable. But it is not anywhere on the C drive (where everything else ST is installed).
I remember I installed it with/through CubeIDE, does it mean it is not an .EXE on the drive? And so perhaps I also need to install the CubeMX as standalone?
Thank you
- Labels:
STM32CubeMX
‎2025-04-09 11:04 PM
CubeIDE does not contain CubeMX as executable. It is a "plugin", named "Device configuration tool". So yes, install the standalone CubeMX.
‎2025-04-12 10:30 AM
Thank you @Pavel A.
