User Authentication Dialog hangs
shane mattner
Senior
The newest version of CubeIDE requires a sign-in to myST, but the dialog box hangs on Ubuntu.  Pretty frustrating...
14 REPLIES 14
Rim LANDOLSI
Hello @shane mattner ,
The issue is not reproduced from my side. Please, try to verify the network connection.
Thanks,
Rim
mccabehm
Senior
With CubeIDE version 1.13.2 on Windows I also am unable to sign-in. This started ~Nov 6, 2023. Prior to that, no problem.
quackquack
This happened to me as well on Linux, after several retries it worked.
Oskar_H
Senior
@shane mattner what is the version of your Ubuntu ? Does the bug still occur in 1.14.0 release ?
 @quackquack what are your Linux distribution and version ?
CubeMX version 6.9.2, Linux Mint 20.3. I selected a new MCU and when I wanted to generate the code it presented a blank dialog box, presumably for downloading related files. Retrying a few times eventually showed a login form. The internet was working fine at the time.
JamesGordon
I'm struggling to log in with the myST link as well - I have Version 1.15.0, on a Windows 10
DexterousMuffin
I cannot login to my-ST as well, I get stuck on User Authentication Dialog forever, with the lines bumping as if it was loading.
I'm running version 1.15.1, on Ubuntu 24.04.
norlesh
I'm actually trying to use it on a fresh windows 11 installation and can confirm the Piece of S**T doesn't work here either!
I've booted a new system, with Ubuntu 22.04, and tested Cube IDE version 1.15.1 and 1.14.0.  It won't let me login anyway, so I guess they're having a server issue.
