UART is not working
demir
Senior II
I have checked connections and assured that everything is set up correctly. When I run the below code, I cant see anything on serial console.
Does anyone have any idea about the root cause ?
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * Copyright (c) 2024 STMicroelectronics.
  * All rights reserved.
/* USER CODE END Header */
#include "main.h"
/* Private includes ----------------------------------------------------------*/
#include <string.h>
#include <stdio.h>
/* USER CODE END Includes */
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* USER CODE BEGIN PM */
/* USER CODE END PM */
RTC_HandleTypeDef hrtc;
UART_HandleTypeDef huart2;
/* USER CODE BEGIN PV */
RTC_TimeTypeDef RTC_TimeRead;
RTC_DateTypeDef RTC_DateRead;
/* USER CODE END PV */
static void MX_RTC_Init(void);
static void MX_USART2_UART_Init(void);
/* USER CODE BEGIN PFP */
char* getDayofWeek(uint8_t number);
char msg[200] ={0};
char msg2[200]={0};
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  MX_GPIO_Init();
  MX_RTC_Init();
  MX_USART2_UART_Init();
  /* USER CODE BEGIN 2 */
  char *msg4 = "message4\n\r";
  HAL_UART_Transmit(&huart2, (uint8_t*)msg4,strlen(msg4),1000);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
	  char *msg3 = "message3\n\r";
	  HAL_UART_Transmit(&huart2, (uint8_t*)msg3,strlen(msg3),1000);
		HAL_RTC_GetTime(&hrtc, &RTC_TimeRead, RTC_FORMAT_BIN);
		HAL_RTC_GetDate(&hrtc, &RTC_DateRead,RTC_FORMAT_BIN);
		sprintf(msg,"current time is: %02d:%02d:%02d\r\n",RTC_TimeRead.Hours,RTC_TimeRead.Minutes,RTC_TimeRead.Seconds);
		HAL_UART_Transmit(&huart2, (uint8_t*)msg,strlen(msg),1000);
		HAL_Delay(1000);
		sprintf(msg2,"current date is:%02d-%02d-%02d-%s\r\n",RTC_DateRead.Month,RTC_DateRead.Date, RTC_DateRead.Year,getDayofWeek(RTC_DateRead.WeekDay));
		HAL_UART_Transmit(&huart2, (uint8_t*)msg2,strlen(msg2),1000);
		HAL_Delay(1000);
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
void SystemClock_Config(void)
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_LSE;
  RCC_OscInitStruct.LSEState = RCC_LSE_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLM = 8;
  RCC_OscInitStruct.PLL.PLLN = 50;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV4;
  RCC_OscInitStruct.PLL.PLLQ = 7;
    Error_Handler();
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
  * @brief RTC Initialization Function
  * @PAram None
  * @retval None
  /* USER CODE BEGIN RTC_Init 0 */
  /* USER CODE END RTC_Init 0 */
  RTC_TimeTypeDef sTime = {0};
  RTC_DateTypeDef sDate = {0};
  /* USER CODE BEGIN RTC_Init 1 */
  /* USER CODE END RTC_Init 1 */
  /** Initialize RTC Only
  hrtc.Instance = RTC;
  hrtc.Init.HourFormat = RTC_HOURFORMAT_12;
  hrtc.Init.AsynchPrediv = 127;
  hrtc.Init.SynchPrediv = 255;
  hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;
  hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
  hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
  if (HAL_RTC_Init(&hrtc) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN Check_RTC_BKUP */
  /* USER CODE END Check_RTC_BKUP */
  /** Initialize RTC and set the Time and Date
  sTime.Hours = 0x12;
  sTime.Minutes = 0x11;
  sTime.Seconds = 0x10;
  sTime.TimeFormat = RTC_HOURFORMAT12_PM;
  sTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
  sTime.StoreOperation = RTC_STOREOPERATION_RESET;
  if (HAL_RTC_SetTime(&hrtc, &sTime, RTC_FORMAT_BCD) != HAL_OK)
    Error_Handler();
  sDate.WeekDay = RTC_WEEKDAY_TUESDAY;
  sDate.Month = RTC_MONTH_JUNE;
  sDate.Date = 0x12;
  sDate.Year = 0x18;
  if (HAL_RTC_SetDate(&hrtc, &sDate, RTC_FORMAT_BCD) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN RTC_Init 2 */
  /* USER CODE END RTC_Init 2 */
  * @brief USART2 Initialization Function
  * @PAram None
  * @retval None
  /* USER CODE BEGIN USART2_Init 0 */
  /* USER CODE END USART2_Init 0 */
  /* USER CODE BEGIN USART2_Init 1 */
  /* USER CODE END USART2_Init 1 */
  huart2.Instance = USART2;
  huart2.Init.BaudRate = 115200;
  huart2.Init.WordLength = UART_WORDLENGTH_8B;
  huart2.Init.StopBits = UART_STOPBITS_1;
  huart2.Init.Parity = UART_PARITY_NONE;
  huart2.Init.Mode = UART_MODE_TX_RX;
  huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart2.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart2) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN USART2_Init 2 */
  /* USER CODE END USART2_Init 2 */
  * @brief GPIO Initialization Function
  * @PAram None
  * @retval None
/* USER CODE BEGIN MX_GPIO_Init_1 */
/* USER CODE END MX_GPIO_Init_1 */
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  /*Configure GPIO pin : PA0 */
  GPIO_InitStruct.Pin = GPIO_PIN_0;
  GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING;
  /* EXTI interrupt init*/
  HAL_NVIC_SetPriority(EXTI0_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(EXTI0_IRQn);
/* USER CODE BEGIN MX_GPIO_Init_2 */
/* USER CODE END MX_GPIO_Init_2 */
/* USER CODE BEGIN 4 */
	char* weekday[] = {"monday","tuesday","wednesday","thursday","friday","saturday","sunday"};
	return weekday[number-1];
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  __disable_irq();
  while (1)
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @PAram  file: pointer to the source file name
  * @PAram  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
18 REPLIES 18
I have updated the ST Link firmware and issue disappeared. I can test that UART is working, I have just written a simple code to check and I can see via serial console that UART is fine.
On the other hand, the original issue still persists.
Not sure I understand this comment. You've already succeeded to make UART working, what do you expect?
You need to start based on this working UART simple code and add step by step more code and check at each step where it fails. This is how to find and debug the issues.
PS:
I thought the original issue was that the UART didn't work?
So, if you can now see that the UART is fine, what's the remaining problem?
I still can not see any message on console printed when I run below code. I have debugged it and came to know, there is problem at SystemClock_Config(); yet I do not know what the issue, please see clock configuration in below as well.
  * @file           : main.c
  * @attention
#include "main.h"
#include <string.h>
#include <stdio.h>
char msg[200] ={0};
char msg2[200]={0};
  * @retval int
int main(void)
  HAL_Init();
	char *msg5 = "msg5 is here to check if this line reachable\n\r";
	HAL_UART_Transmit(&huart2, (uint8_t*)msg5, strlen(msg5),1000);
  MX_GPIO_Init();
  MX_RTC_Init();
  /* Infinite loop */
  while (1)
	  HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_14);
		HAL_Delay(1000);
		HAL_Delay(1000);
		 HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_15);
  * @retval None
    Error_Handler();
    Error_Handler();
  * @PAram None
  * @retval None
    Error_Handler();
  sTime.Hours = 0x12;
    Error_Handler();
  sDate.Date = 0x12;
  sDate.Year = 0x18;
    Error_Handler();
  * @PAram None
  * @retval None
    Error_Handler();
  * @PAram None
  * @retval None
  __HAL_RCC_GPIOD_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(GPIOD, GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15, GPIO_PIN_RESET);
  /*Configure GPIO pins : PD12 PD13 PD14 PD15 */
  GPIO_InitStruct.Pin = GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
  * @retval None
  __disable_irq();
  while (1)
  * @retval None
 I have also commented out SystemClock_Config() and debugged again, this time error_handler() is called t MX_RTC_Init() function.
I suspect that, there is something wrong with my clock configuration, I just can not see what that is.
When I commented out MX_RTC_Init() function, the application runs flawlessly. Thus, after debugging I made it sure that the problem is with initialization of both system clock and RTC.
I hope I have made the topic clear, else please let me know for further information. Thanks for the support, much appreciated.
So, really, you have fixed the original problem - "UART is not working" - and now you have a different problem?
It would be better to mark the solution to your "UART is not working" problem, and start a new thread for the new problem.
Give a link here to the new thread, so people can find it.
Also give a link back to here in the new thread for reference.
This is what I suggested him in my first comment in this thread.
@demir Could you please close this thread by selecting one of the comments that solved your UART problem? or give the solution here and close it after?
PS:
You might be confusing threads, as I didnt write on that thread which you are referring to.
Also, please note that, the original problem was not UART non functioning. The original problem is that my code is not scheduled, it is stuck at SystemClock_Config() and when I commented out this part, then the application gets stuck at MX_RTC_Init() function. Please see the previous message I have sent on this thread. I have explained the original issue in greater detail.
That was the original question, therefore it does not make sense to accept one of the answers as solution. Please correct me if I am mistaken.
Thank you for your support.
Right - that is very confusing!
The title of the thread is "UART is not working", and the initial post is all focussed on the UART not working.
So perhaps the best thing would be to close-off this thread with a post saying, "it wasn't the UART after all", and then start a new thread with the question about SystemClock_Config()  - and without all the UART distraction ?
Again, with links.
I dont read all, but primary is your code copy from ... or generated in MX right way?
Have your board LSE ?
I am crating new thread as per request, please find details in there.
