STM32CubeIDE hangs on start today !
AScha.3
Chief II
starting IDE , stays here:
0693W00000aJG4aQAG.pngonly kill with taskmanager possible.
problem exist when starting IDE today, yesterday and before was no problem.
yesterday i closed it as usual and shut down PC.
today - no start. but when i choose other workspace, it is starting. (but no projects there).
so: how to get workspace working again?
log for today shows:
!SESSION 2023-03-18 09:09:48.006 -----------------------------------------------
eclipse.buildId=Version 1.10.1
java.version=11.0.14.1
java.vendor=Eclipse Adoptium
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=de_DE
Command-line arguments:  -os linux -ws gtk -arch x86_64
!ENTRY com.st.stm32cube.ide.mcu.informationcenter 4 4 2023-03-18 09:09:57.719
!MESSAGE CubeMX plugin appears to be active, Log4j initialization might be too late.
 and in other (almost empty) workspace IDE is starting, this is begin of log:
!SESSION 2023-03-18 09:19:32.494 -----------------------------------------------
!ENTRY com.st.stm32cube.ide.mcu.informationcenter 4 4 2023-03-18 09:29:01.878
!ENTRY com.st.stm32cube.ide.mcu.informationcenter 1 1 2023-03-18 09:29:01.998
!MESSAGE Log4j initialized with config file /home/alfsch/STM32CubeIDE/workspace_1.1.0/.metadata/.log4j.xml
!ENTRY org.eclipse.e4.ui.workbench 2 0 2023-03-18 09:29:04.499
!MESSAGE Removing PartDescriptorImpl with the "com.st.stm32cube.ide.mcu.debug.swv.core.DTWExceptionEvent" id and the "SWV Exception Timeline Graph" label.It points to the non available "bundleclass://org.eclipse.ui.workbench/org.eclipse.ui.internal.e4.compatibility.CompatibilityView" class. Bundle might have been uninstalled
!ENTRY org.eclipse.e4.ui.workbench 2 0 2023-03-18 09:29:04.524
!MESSAGE Removing PartDescriptorImpl with the "org.eclipse.rse.shells.ui.view.commandsView" id and the "Remote Shell" label.It points to the non available "bundleclass://org.eclipse.ui.workbench/org.eclipse.ui.internal.e4.compatibility.CompatibilityView" class. Bundle might have been uninstalled
!ENTRY org.eclipse.e4.ui.workbench 2 0 2023-03-18 09:29:04.525
!MESSAGE Removing PartDescriptorImpl with the "org.eclipse.rse.ui.view.systemView" id and the "Remote Systems" label.It points to the non available "bundleclass://org.eclipse.ui.workbench/org.eclipse.ui.internal.e4.compatibility.CompatibilityView" class. Bundle might have been uninstalled
AScha.3
Chief II
i think i found it:
https://stackoverflow.com/questions/73496451/stm32-cube-ide-after-initial-successfull-launch-and-use-now-remains-idle-durin
Workaround
To fix this, just remove this file inside your workspace:
.metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi
Hope this solves the issue.
(this file is the responsible of saving your workbench layout)
now workspace starting again, just have to set all window sizes again.
AScha.3
Chief II
i think i found it:
Workaround
Piranha
Chief II
Exactly as I described Eclipse in this topic...
https://community.st.com/s/question/0D53W00000U7PcHSAV/keil-vs-stm-ide
