stm32 I2c won't send data
fontys_student
I am trying to get to use I2C on my stm32L4R5ZIT-P.
i am trying to configure a sensor by sending data but the I2C pins wont give a signal?
i dont ude interups or DMA
these are the pins that i use and the setting for I2C:
this are the includes i use
this is my code. i don't have any errors or warnings in the code
how do i fix it and make shure i can send data out?
7 REPLIES 7
Guru
Does HAL_I2C_IsDeviceReady return HAL_OK? Do your other functions return HAL_OK?
Bob S
Principal
What do you mean "won't give a signal"?  Are you looking at the SDA and SCL lines with a scope or logic analyzer?
"I don't have any errors or warnings in the code" -> means no compiler errors or warning.  You need to check the return values from the HAL calls. Do you call MX_I2C2_Init() somewhere before the code you posted?
Is this a custom board or one of the ST Nucleo (or Disco?) boards?  Are there external pull-up resistors on the SCL/SDA lines?  Using only the STM32's internal pull-ups MAY work for testing but should not be relied on in a production device - they are too high a resistance.
Also, when posting code, please don't post images, copy/paste the code into the forum message using the code tags (click on the "..." button then "</>").
i am new to the stm platform. where can i see if the functions give a HAL_OK
It will be the return value from the function call; eg,
HAL_StatusTypeDef result; // for the return value from HAL function calls
result = HAL_I2C_IsDeviceReady( &hi2c2, 0x40<<1, 10, 1000 );
BTW: rather than writing `0x40<<1` as a Magic Number, it would be better style to give it a meaningful name; eg,
#define SENSOR_I2C_ADDRESS (0x40<<1)
then you can write:
result = HAL_I2C_IsDeviceReady( &hi2c2, SENSOR_I2C_ADDRESS, 10, 1000 );
Which is not only clearer & easier to understand, but also easier to maintain; eg, if you find that the address needs changing...
Andrew Neil
Evangelist III
when i try do this i get a HAL_busy back
this is my full code. i use the internal pullup of the stm 32
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * Copyright (c) 2024 STMicroelectronics.
  * All rights reserved.
/* USER CODE END Header */
#include "main.h"
/* Private includes ----------------------------------------------------------*/
#include "stm32L4xx_hal_i2c.h"
#include <string.h>
#include <stdio.h>
/* USER CODE END Includes */
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* USER CODE BEGIN PM */
/* USER CODE END PM */
I2C_HandleTypeDef hi2c2;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
static void MX_I2C2_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  MX_GPIO_Init();
  MX_I2C2_Init();
  /* USER CODE BEGIN 2 */
if (HAL_I2C_EnableListen_IT(&hi2c2) != HAL_OK)
	Error_Handler();
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  //configuration reset
while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
uint8_t confReset[2];
confReset[0] = 0x80;
confReset[1] = 0x00;
uint8_t conf;
conf = 0x00;
uint8_t confVal[2];
		  confVal[0] = 0x39;
		  confVal[1] = 0x9F;
uint8_t cal;
cal = 0x05;
uint8_t calVal[2];
calVal[0] = 0x57;
calVal[1] = 0x62;
/* Infinite loop */
HAL_I2C_Master_Transmit(&hi2c2, 0x40<<1, confReset, 2, 10);
//configuration setup
HAL_I2C_Mem_Write (&hi2c2, 0x40<<1, conf, 1, confVal, 2, 10);
HAL_I2C_Mem_Write (&hi2c2, 0x40<<1, cal, 1, calVal, 2, 10);
	  	  // HAL_I2C_Mem Write (hi2c, (0x40<<1), 32768, 16, addata, Size, Timeout);
	  	  // HAL I2C_Mem Read (hi2c, DevAddress, MemAddress, MemAddSize, pData, Size, Timeout);
	    /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
void SystemClock_Config(void)
  if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK)
    Error_Handler();
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLM = 1;
  RCC_OscInitStruct.PLL.PLLN = 16;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
  RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV4;
    Error_Handler();
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_3) != HAL_OK)
    Error_Handler();
  * @brief I2C2 Initialization Function
  * @PAram None
  * @retval None
  /* USER CODE BEGIN I2C2_Init 0 */
  /* USER CODE END I2C2_Init 0 */
  /* USER CODE BEGIN I2C2_Init 1 */
  /* USER CODE END I2C2_Init 1 */
  hi2c2.Instance = I2C2;
  hi2c2.Init.Timing = 0x10707DBC;
  hi2c2.Init.OwnAddress1 = 0;
  hi2c2.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT;
  hi2c2.Init.DualAddressMode = I2C_DUALADDRESS_DISABLE;
  hi2c2.Init.OwnAddress2 = 0;
  hi2c2.Init.OwnAddress2Masks = I2C_OA2_NOMASK;
  hi2c2.Init.GeneralCallMode = I2C_GENERALCALL_DISABLE;
  hi2c2.Init.NoStretchMode = I2C_NOSTRETCH_DISABLE;
  if (HAL_I2C_Init(&hi2c2) != HAL_OK)
    Error_Handler();
  /** Configure Analogue filter
  if (HAL_I2CEx_ConfigAnalogFilter(&hi2c2, I2C_ANALOGFILTER_ENABLE) != HAL_OK)
    Error_Handler();
  /** Configure Digital filter
  if (HAL_I2CEx_ConfigDigitalFilter(&hi2c2, 0) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN I2C2_Init 2 */
  /* USER CODE END I2C2_Init 2 */
  * @brief GPIO Initialization Function
  * @PAram None
  * @retval None
/* USER CODE BEGIN MX_GPIO_Init_1 */
/* USER CODE END MX_GPIO_Init_1 */
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOF_CLK_ENABLE();
/* USER CODE BEGIN MX_GPIO_Init_2 */
/* USER CODE END MX_GPIO_Init_2 */
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  __disable_irq();
  while (1)
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @PAram  file: pointer to the source file name
  * @PAram  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
Guru
Start with blocking functions. Call HAL_I2C_IsDeviceReady and ensure it returns HAL_OK before calling any other I2C function. Don't call HAL_I2C_EnableListen_IT at the start.
