STM CUBE IDE can not program the board.
2023-12-20 02:11 AM
Hi All,
I am having an issue which is persistent for more than a week. I created a simple blink LED program using STM32 CUBE IDE IDE. I compiled it OK. Then, I tried to run it on the board, CUDE IDE got stuck. I can see from the progress bar that Launching: initializing debugger services. The progress is stuck at %51 and does not change even if I wait for ages. To identify the root cause, I tried below steps.
- I tried with another cable but didnt work
- I tried with another version of STM CUBE IDE (1.13.0) and it did not work
- I tried to program the board with STM Cube programmer and it WORKED, I was able to blink the LED.
- I tried to use another PC and it also WORKED
So, it got me thinking that STM CUBE IDE on my PC has something wrong. As I can not purchase another laptop as a solution, I am looking forward to hearing some help from the community. Please see attachments and provide me some guidance.
Thank you in advance.
2023-12-20 04:01 AM
2023-12-20 04:27 AM
Sorry Mahmoud, I totally forgot that.
It is ST32F407G-DISC1 (MB997E).
2023-12-21 01:59 AM
Hello @demir ,
For more investigations, I suggest that you provide please the Debug session configurations and the Project.build.log File. You can find it under Properties (Alt+Enter)> C/C++ Build>Logging.
Thanks.
Mahmoud.
2023-12-21 02:19 AM
Hi Mahmoud,
Please find it below.
09:28:42 **** Incremental Build of configuration Debug for project blinking ****
make -j8 all
arm-none-eabi-gcc -o "blinking.elf" @"objects.list" -mcpu=cortex-m4 -T"C:\Users\blinking\STM32F407VGTX_FLASH.ld" --specs=nosys.specs -Wl,-Map="blinking.map" -Wl,--gc-sections -static --specs=nano.specs -mfpu=fpv4-sp-d16 -mfloat-abi=hard -mthumb -Wl,--start-group -lc -lm -Wl,--end-group
Finished building target: blinking.elf
arm-none-eabi-size blinking.elf
arm-none-eabi-objdump -h -S blinking.elf > "blinking.list"
text data bss dec hex filename
35620 132 4124 39876 9bc4 blinking.elf
arm-none-eabi-objcopy -O ihex blinking.elf "blinking.hex"
Finished building: default.size.stdout
arm-none-eabi-objcopy -O binary blinking.elf "blinking.bin"
Finished building: blinking.list
Finished building: blinking.hex
Finished building: blinking.bin
"make -j8 all" terminated with exit code -1. Build might be incomplete.
09:28:49 Build Finished. 0 errors, 0 warnings. (took 6s.963ms)
2023-12-23 04:05 PM - edited 2023-12-23 04:06 PM
Why?
Can you check how much free space you have on the disk?
In the project settings, remove creation of bin and hex files unless you need them specifically.
2023-12-23 11:52 PM
Seems your build config is ok , but debuger setup completely fail. create new debug configuration in debug button menu.
2023-12-24 07:18 AM - edited 2023-12-24 07:48 AM
Hi Pavel,
Hex and bin files are already not generated. I have 48gb available disk space.
I dont know why the build fails, how can I correct it ?
2023-12-24 07:20 AM - edited 2023-12-24 07:49 AM
I havent played with configuration, it is all default. Could you pls direct me what to check ?
2023-12-25 03:03 PM
Everything looks good, except of the unexplainable make error. Then it looks indeed like a problem with your computer. Windows is a complicated system, too many things can go wrong in it.
