Rx buffer is evaluating
sid19
I am new to STM IDE.
I am using STM32 Cubemx with SIMCOM 7600C1. The code is in attachment.
I dont know what is happening but throwing following error:
Multiple errors reported.
1) Failed to execute MI command:
-var-create - * rx_buffer
Error message from debugger back end:
-var-create: unable to create variable object
2) Unable to create variable object
3) Failed to execute MI command:
-data-evaluate-expression rx_buffer
No symbol "rx_buffer" in current context.
4) Failed to execute MI command:
These are the error coming after debugging
1 REPLY 1
KDJEM.1
Hello @sid19 and welcome to the Community,
Could you please give more details about issue. Please take a look at this https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
Which STM32 MCU are using? Are you using a STM32 board?
Which STM32CubeIDE version are you using?
Ensure that the variable rx_buffer is properly declared and initialized in your code.
Please take a look at this post may help  you.
Thank you.
Kaouthar
