IDE keep calling Upgrade utility and crashes after just a few seconds
Mogical
Hello! Just started my IDE this morning after working on the same version and same configs the night earlier and the IDE now keep crashing whatever i'm doing. This is the last logs i have on the .ide.log file :
2024-09-18 12:43:28,471 [FATAL] Updater:334 - Updater called before beeing initialized
2024-09-18 12:43:28,471 [ERROR] CADModel:125 - Updater not yet initialized, retry later
2024-09-18 12:43:28,473 [FATAL] Updater:334 - Updater called before beeing initialized
2024-09-18 12:43:28,554 [FATAL] Updater:334 - Updater called before beeing initialized
2024-09-18 12:43:28,558 [INFO] DbMcusAds:53 - JSON generation date=Mon Sep 16 16:40:22 CEST 2024 (1726497622318)
2024-09-18 12:43:28,558 [FATAL] Updater:334 - Updater called before beeing initialized
2024-09-18 12:43:28,579 [WARN] DetailPanel:346 - Failed to get advertising image, set to default
2024-09-18 12:43:28,634 [FATAL] Updater:334 - Updater called before beeing initialized
2024-09-18 12:43:28,636 [FATAL] Updater:334 - Updater called before beeing initialized
2024-09-18 12:43:28,636 [WARN] DetailPanel:346 - Failed to get advertising image, set to default
2024-09-18 12:43:28,637 [FATAL] Updater:334 - Updater called before beeing initialized
2024-09-18 12:43:28,664 [ERROR] Updater:1164 - MainUpdater not yet initialized. External WinMGr cannot be set.
2024-09-18 12:43:28,666 [INFO] Updater:1100 - Updater Version found : 6.12.0
2024-09-18 12:43:28,686 [INFO] ApplicationProperties:184 - Using Application install path: C:\ST\STM32CubeIDE_1.16.0\STM32CubeIDE\plugins\com.st.stm32cube.common.mx_6.12.0.202406281431
2024-09-18 12:43:28,707 [INFO] MainUpdater:5296 - Software Update Detected: STM32CubeMX
2024-09-18 12:43:30,147 [INFO] UpgradeLauncher:84 - Launching upgrade utility for software upgrade type: (MX) upgradeMode ( Rel)
2024-09-18 12:43:30,158 [INFO] UpgradeLauncher:93 - Upgrade utility launched for software upgrade
All the Updater says is "Self Upgrade failed. Trying to restore" then crashes.
I tried a few things such as creating a new workspace, disabling auto updates, offline mode, reinstalling, deleting plugins, etc...
4 REPLIES 4
Torsen
Same story here, however in my case appears cubeMX update may have caused this.
So now for any of the STM suite software to launch requires admin privilege. This is new.
cleonb322
How did you solve this issue?
Run it as administrator.
zhenyu
I resolved with this issue by update the cubeMX to latest version. I do resloved
