September 19, 2024
Linter for CubeIDE
  • September 19, 2024
  • 1 reply
  • 1186 views
are there some plugins, extensions of free linters that can be used with CubeIDE?
If not, what are the best solutions?
Thank you
Best answer by mƎALLEm
Hello @Ricko,
Check out these links as they may help you:
https://mcuoneclipse.com/2020/12/29/eclipse-codan-static-code-analysis-for-c-c/
https://marketplace.eclipse.org/free-tagging/linter
https://wiki.eclipse.org/images/f/f9/CodanCDTSummit2010.pdf
Or simply google C code analyzer Eclipse plugin
Hope it helps.
1 reply
mƎALLEm
mƎALLEmBest answer
Hello @Ricko,
Hope it helps.
