Problem importing stm32cubeide project into new workspace
‎2023-08-02 05:04 AM
I have several stm32cubeide projects in a workspace (the projects are NOT under the workspace folder)
All of the projects compile correctly in the original workspace.
Now I want to import several of the projects to another workpace.
I created a new workspace and imported two of the projects to the new workspace (using Import/Existing Projects into Workspace)
One of the project compiles OK, but the other does not.
the error I get is :
Error: Program "make" not found in PATH
PATH=[C:/ST/STM32CubeIDE_1.12.1/STM32CubeIDE//plugins/com.st.stm32cube.ide.jre.win64_3.0.0.202305091045/jre/bin/server;C:/ST/STM32CubeIDE_1.12.1/STM32CubeIDE//plugins/com.st.stm32cube.ide.jre.win64_3.0.0.202305091045/jre/bin;C:\Program Files\Microsoft\jdk-11.0.16.101-hotspot\bin;C:\Python310\Scripts\;C:\Python310\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\nodejs\;C:\ProgramData\chocolatey\bin;C:\Program Files\Microsoft SQL Server\150\Tools\Binn\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\170\Tools\Binn\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Program Files (x86)\GitExtensions\;C;C:\Program Files\dotnet\;C:\Program Files\Git\cmd;C:\Program Files\Docker\Docker\resources\bin;C:\Program Files\GitHub CLI\;C:\Users\nadav\AppData\Local\Microsoft\WindowsApps;C:\Users\nadav\AppData\Roaming\npm;C:\Users\nadav\AppData\Local\Programs\Microsoft VS Code\bin;C:\Users\nadav\AppData\Local\GitHubDesktop\bin;C:\Users\nadav\.dotnet\tools;C:\ST\STM32CubeIDE_1.12.1\STM32CubeIDE]
I noticed than in the Includes node of the project,
in the project in the original workspace there several references to folders under
C:/ST/STM32CubeIDE_1.12.1/STM32CubeIDE/..
In the new workspace these references are missing.
Can anybody please help me solve this problem..
thanks,
Nadav
‎2023-08-02 06:37 AM
Try copying it manually to the new workspace folder and opening the .project file from there.
‎2023-08-02 07:07 AM
Still same problem...
Thanks,
Nadav
‎2023-08-02 07:54 AM - edited ‎2023-08-02 07:54 AM
This is strange. Can you tell again, what is your current CubeIDE version and in what version these projects have been created?
The path for make should be automatically pre-pended by CubeIDE, and it must be somewhere under eclipse plugins. But your listing does not show it.
‎2023-08-03 12:12 AM
I am using STM32CubeIDE Version: 1.13.1 Build: 17479_20230728_0839 (UTC)
The projects were created on this IDE from examples (LwIP_HTTP_Server_Netconn_RTOS & UART_Printf examples)
the UART_Printf project compiles after importing,
the LwIP_HTTP_Server_Netconn_RTOS does not compiles after importing...
I just recreated the LwIP_HTTP_Server_Netconn_RTOS project, and now it imports correctly...
this is weird...
Nadav
