2020-02-25 12:47 PM
Could not determine GDB version using command: /opt/st/stm32cubeide_1.2.0/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.linux64_1.0.0.201904181610/tools/bin/arm-none-eabi-gdb --version
/opt/st/stm32cubeide_1.2.0/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.linux64_1.0.0.201904181610/tools/bin/arm-none-eabi-gdb: error while loading shared libraries: libncurses.so.5: cannot open shared object file: No such file or directory
2024-05-04 11:51 AM
my Ubuntu Version is 24.04 LTS
and its not working
2024-05-07 02:24 AM
Thank you, still working on Ubuntu 24.04
2024-08-09 04:01 AM
Many thanks very usefull
2024-09-12 06:44 AM
Thanks! Adding the repository was the solution for me.
Hope ST fixes next versions in order to use libncurses6
2024-10-03 08:33 AM
I'm getting the same error but when I try the above command I get "unable to locate package libncurses5"????
2024-10-04 07:52 AM
ST has a real problem here as evidenced by the number of respondents. What needs to happen ASAP is a rebuild using libncurses.so.6. Looking across the net, it appears that 6 alleviates some long existing security issues. Version 5 is not even on option in my Mint/Ubuntu 22 Kernel 6.8 distribution. I finally resulted begrudgingly, to drop back to windows.
Good Luck All.
2024-10-04 07:54 AM
Object-Option not available in my distribution.
