2023-01-29 04:24 PM
According to the data sheet for this device, I should be able to attached an external High speed crystal instead of using the HSI RC. However, I can't seem to figure out how to do this using the STM32CubeMX utility.
2023-01-29 11:45 PM
so simple:
2 . set frequ.in clock tree and pll
ok ?
2023-01-30 12:07 AM
as @AScha.3 said, its quite straight foward.
Are you using any nucleo/discovery board? or you go custom
