2025-01-15 03:40 AM - last edited on 2025-01-15 04:26 AM by Andrew Neil
Hello everyone.
I'm starting to work with ST .
Working on nucleo-g071rb.
I watched the videos.
I turned on an LED and managed to send a string on the UART.
I'm trying to define an array or variables and I can't.
I worked in a different environment, Atmel's codvizion.
Apparently the syntax is different.
I work in the C language.
How can I learn to define variables from arrays and such...
My project is supposed to have buttons. Turn on LEDs accordingly. Send a word according to the button via the heart.
Get OK confirmation
I'm really starting with ST .
I can't define variables from arrays and such..
I'd appreciate help
For example programs
Thanks Yitzhak.
2025-01-15 04:24 AM
@User1658312518282898261 wrote:I'm starting to work with ST ..
Are you familiar with any other microcontroller(s)?
Are you familiar with C programming? With programming in general ?
Here are some getting started tips:
Please also see the posting guide for this forum:
@User1658312518282898261 wrote:I'm trying to define an array or variables and I can't.
So show us what you tried, and tell what problem(s) you had - see the posting guide for how to post code
@User1658312518282898261 wrote:I worked in a different environment, Atmel's codvizion.
You mean this: https://www.codevision.be/ ?
I've not used it, but it says that it's "ANSI C" - so should be no syntax differences.
@User1658312518282898261 wrote:How can I learn to define variables from arrays and such....
That's standard C programming stuff - so any C reference, textbook, or tutorial should cover that.
Here's some C learning & reference materials - including a free online textbook:
https://blog.antronics.co.uk/2011/08/08/so-youre-thinking-of-starting-with-c/
