2021-10-05 03:04 PM
How can I display double or longlong variables (as human readable floating point or integer values) in the cube ide debugger please?.
2021-10-05 03:29 PM
Same way as you view any other variable. View them in Variables or add them to Expressions as desired. What issue are you running into?
2021-10-05 03:29 PM
2021-10-07 11:47 AM
Harrumph (shuffles feet awkwardly) - yes, that does indeed work. Quite why it didnt appear to be working the other night I don't quite understand. Thankyou!
