2024-11-18 05:46 AM - last edited on 2024-11-18 05:54 AM by Andrew Neil
I am facing a small but very boring issue with the Resume (F8) button of the top tool bar.
This button is active when it should not be, while download is in progress and if you click on it, the download fails.
This behavior is systematic.
Randomly, it is inactive when the download has finished.
This issue is not frequent, but it leads to same result, the download must be restarted to be able to launch the debug session.
2024-11-18 05:53 AM - edited 2024-11-18 06:01 AM
Hello @zeboss49 ,
Escalated to internal teams for further analysis (internal ticket for follow-up 196491).
Hello @zeboss49 ,
2024-11-19 07:19 AM
FYI;
Reproduced internally .. under analysis.
