Cube IDE 1.15.0
‎2024-04-01 04:45 AM
Hi all,
Installed the latest CubeIDE and re-built an existing project. Got several warnings. One of them was
RWX. This could be solved by making changes to the ,ld file. Example - .ARM (READONLY)
The next issues was -- > "_close is not implemented and will always fail". Don't know how to solve this warning.
I believe these problems are due to latest version GCC.
Another issue I noticed is - memory regions have disappeared. I have a correctly name list file but to no avail.
Can someone please help me solve these issues. Please help. Thanks.
NPS
STM32CubeIDE
‎2024-04-01 07:25 AM
Hello @Parmin Nayani
This is a known issue that will be fixed on the next releases. As a temporary workaround, in main.c file, add these instructions:
__attribute__((weak)) void _close(void){}
__attribute__((weak)) void _lseek(void){}
__attribute__((weak)) void _read(void){}
__attribute__((weak)) void _write(void){}
Between "/* USER CODE BEGIN Includes */" and "/* USER CODE END Includes */".
Best Regards.
STTwo-32
‎2024-04-01 05:07 AM - edited ‎2024-04-01 05:09 AM
Could you please take a look at this post. It should be helpful.
Best Regards.
STTwo-32
‎2024-04-01 05:11 AM
I seem to miss "Could you please take a look at this post. It should be helpful." link. Can you post the link please? Thank you.
‎2024-04-01 05:15 AM
I've added the link sorry for this mistake.
Best Regards.
STTwo-32
‎2024-04-01 05:38 AM
Hi STTwo-32,
I did as suggested but the warnings are persisting. Here are the warnings
C:/ST/STM32CubeIDE_1.15.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.100.202403111256/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: C:/ST/STM32CubeIDE_1.15.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.100.202403111256/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v7-m/nofp\libc_nano.a(libc_a-closer.o): in function `_close_r':
(.text._close_r+0xc): warning: _close is not implemented and will always fail
C:/ST/STM32CubeIDE_1.15.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.100.202403111256/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: C:/ST/STM32CubeIDE_1.15.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.100.202403111256/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v7-m/nofp\libc_nano.a(libc_a-lseekr.o): in function `_lseek_r':
(.text._lseek_r+0x10): warning: _lseek is not implemented and will always fail
C:/ST/STM32CubeIDE_1.15.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.100.202403111256/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: C:/ST/STM32CubeIDE_1.15.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.100.202403111256/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v7-m/nofp\libc_nano.a(libc_a-readr.o): in function `_read_r':
(.text._read_r+0x10): warning: _read is not implemented and will always fail
C:/ST/STM32CubeIDE_1.15.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.100.202403111256/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: C:/ST/STM32CubeIDE_1.15.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.100.202403111256/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v7-m/nofp\libc_nano.a(libc_a-writer.o): in function `_write_r':
(.text._write_r+0x10): warning: _write is not implemented and will always fail
C:/ST/STM32CubeIDE_1.15.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.100.202403111256/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe: warning: 12CSN_card_reader.elf has a LOAD segment with RWX permissions
Finished building target: 12CSN_card_reader.elf
‎2024-04-01 05:39 AM
No problems. The problem still persists. Please help. Thank you.
‎2024-04-01 05:41 AM
Could you upload your project here.
Best Regards.
STTwo-32
‎2024-04-01 05:51 AM
Can you please elaborate on the project file? What files do you want me to send?
‎2024-04-01 06:00 AM
The warning is for stm32f103c8 controller. I have project for 407 but that compiles without warnings.
‎2024-04-01 06:06 AM
Send all the Project on one of the supported formats on this community (.7z for example).
Best Regards.
STTwo-32
