cmsis_os.h and FreeRTOS.h no such file or directory
‎2021-05-29 7:39 AM
i was watching this tutorial:
https://www.youtube.com/watch?v=OPrcpbKNSjU
Differences between video and what I do:
my card is stm32f411re nucleo64 and i select the tim10 because the tim6 was not visible to me
these are pictures:
FreeRTOS
STM32CubeIDE
STM32F4 Series
‎2021-05-31 3:47 AM
Welcome to STM32 Community!
Please check the include Paths
==> Go to Project options ->C/C++ tab->Include paths and add new paths to your include directories
Imen
‎2021-05-31 4:07 AM
You can also refer to the FreeRTOS example under STM32Cube directory:
Repository\STM32Cube_FW_F4_V1.26.1\Projects\STM32F412G-Discovery\Applications\FreeRTOS
You can check this example and get inspired from them to configure your files
Imen
‎2021-06-04 2:00 PM
hello, thanks for your reply, sorry for the late reply, as you said, I checked the included paths from the project options and as you can see in the picture, I added three new paths and the errors I got were resolved, but this time other errors appeared.
this is the file config i made
these are the new errors i got
‎2021-06-04 2:03 PM
I checked the undefined reference errors about stm32 on the internet but I couldn't find anything useful
and sorry for my bad english
‎2021-06-05 1:59 AM
Well, then learn using the Internet first... The "undefined reference" error means that there are no actual function implementation, which typically means that the corresponding *.c files are missing or not compiled.
‎2021-06-06 5:38 AM
I know how to use the internet before I opened this topic, I looked at dozens of websites and i couldn't find a useful answer and I hope I'll write it here, by the way, thanks for your help, I tried to implement what you said, but it didn't work and I sorry for my bad English.
‎2021-06-06 5:41 AM
I think I should improve myself a little more on cube ide and c programming instead of dealing with the rtos issue for the moment.
‎2021-06-06 5:41 AM
see you
‎2021-11-29 11:29 PM
Hello! we have found a solution to this problem, it is a little unusual.
Try installing CubeIde on another computer, then create a project there and add FreeRTOS. Then move this project to CubeIDE with the malfunction and build. In our case, the problem was solved
