Change target microcontroller
‎2024-09-23 2:27 AM - last edited on ‎2024-09-23 2:31 AM by Andrew Neil
This is a question about STM32CubeIDE.
When creating a new STM32 project, you select the board, but if I select STM32F412 and edit the program, can I operate the STM32H743 microcontroller?
(We will adjust the pin configuration accordingly)
- Labels:
STM32F4 Series
STM32H7 Series
‎2024-09-23 2:31 AM - edited ‎2024-09-23 2:33 AM
@pass3master wrote:This is a question about STM32CubeIDE.
I've moved it to the STM32CubeIDE section, then. And updated the title.
To change the Target microcontroller, See the answer here:
‎2024-09-23 2:29 AM
Hello @pass3master
Could you give some more details.
Best Regards.$
STTwo-32
‎2024-09-24 4:11 PM
Thank you for your reply.
We understand that the hardware target cannot be changed,
so we will consider this problem solved.
