Can i program my STM32F103C8T6 with atollic via USB port?
‎2021-10-06 5:51 AM
I'm use STM32F103C8T6 for some subsytem of UAV. I want to program my STM32 via USB port but i cant find any document for atollic or cube ide. I find only for arduino IDE. What can i do?
Thank you.
- Labels:
STM32CubeIDE
STM32F1 Series
TrueSTUDIO
‎2021-10-06 5:53 AM
Welcome, @BYONE.1​, to the community!
You should consider to use the STM32CubeProgrammer, because programming using USB is usually done using the internal bootloader of the STM32.
/Peter
‎2021-10-06 5:53 AM
/Peter
‎2021-10-06 5:59 AM
Thank you for your reply,
If are there any document or website for that, can you share with me?
/Berkan
‎2021-10-06 6:09 AM
Yes of course - you will get it if you click on the link that I just added for the STM32CubeProgrammer (highlighted in blue).
/Peter
‎2021-10-06 6:10 AM
Hello @BYONE.1​ and welcome to the Community :)
Regarding the program with CubeIDE or Atollic, I advise you to use the examples available under STM32CubeF1 MCU package.
All examples integrate the IDEs: EWARM, MDK, SW4STM32.
So, you can select the suitable example for you using SW4STM32 or IAR, then migrate to STM32CubeIDE or Atollic following these guides:
- UM2579: Migration guide from System Workbench to STM32CubeIDE
- Migration guide from IAR to Atollic TrueSTUDIO
Hope this helps you!
Imen
Imen
