Can not build project - Program "make" not found in PATH
JR2963
Senior II
I’m encountering several errors when trying to build my older project in Atollic TrueStudio. The first error is:
Cannot run program "make": Launching failed
Error: Program "make" not found in PATH
Also in properties C/C++ build is:
Orphaned configuration. No base extension cfg exists for com.st.stm32cube.ide.mcu.gnu.managedbuild.config.exe.debug....
The project no longer has an IOC configuration .IOC
Also I tried to inport it to the STM32IDE - did not help.
Please is there any posiibilites how to compile it?
Another porject works without problems...
JR2963
Senior II
as I said: Anothers projects works perfectly
Pavel A.
You're trying to open in Atollic a project created for CubeIDE. This isn't going to work. Time to upgrade.
