2023-08-16 7:48 AM
Is it possible to use the new SMT32 vs code extension without installing the STM32CubeIDE on ubuntu linux?
2023-08-17 12:43 AM
STM32CubeIDE is not mandatory to use VS Code with STM32
You can take a look at these videos:
You can install STM32Cube...to access more resources
2023-08-17 12:43 AM
2023-08-24 7:23 PM
The problem was with the configuration on the launch.json file. I had to replace the references with actual file paths.
