2024-12-18 1:25 PM
I just updated my version of STM32Cube IDE (1.17.0) on my PC, and I miss the "INITIALIZE ALL PERIPHERALS IN DEFAULT MODE" when I start a new project with my NUCLEO-H723ZG board. Instead of that, I have a new popup, "Board Project Options" with only HMI things, and it results in the ETH not being initialized for example.
Maybe I have missed some settings? Is the "INITIALIZE ALL PERIPHERALS IN DEFAULT MODE" mode still available in this version?
Thank you for your help
2024-12-20 12:56 AM
Hello @PG29 ,
First let me thank you for posting and welcome to the ST Community.
It is a normal behavior, in fact Start From Board is a functionality of STM32CubeMX that simplifies the creation of a project on a board.
In this case, the project can quickly be generated and uploaded to a board.
For more information, I suggest that you take a look at this ST Wiki.
It explains what is Start From Board feature, how to use it through a detailed example and the supported boards.
Best Regards.
Mahmoud
2024-12-20 12:56 AM
Hello @PG29 ,
Best Regards.
Mahmoud
