2022-12-19 10:35 AM
In datasheet, pin 43 as PB0 and pin 44 as PB1. However, it is reversed on the module.
2023-01-27 8:27 AM
Hello @uouox ,
After check internally with @Ghofrane GSOURI , I confirm there is not issue in STM32CubeMx.
However, STM32WB5MMG pin/ball definition table in the datasheet will be updated with
Thank you.
Kaouthar
2022-12-20 1:47 AM
Hello @uouox
Thank you for your contributions and for your detailed explanations,
I confirm the issue on my side, it has been reported to STM32CubeMX development team .
Internal ticket number: 141697 (This is an internal tracking number and is not accessible or usable by customers).
I will keep you posted with updates.
Ghofrane
2023-01-27 8:27 AM
Hello @uouox ,
Thank you.
Kaouthar
