Unable to start FUS. FUS version is 0.0.0.0 and FUS_STATE_ERR_UNKNOWN
KKIM.6
Senior
I'm trying to fix a P-Nucleo-WB55 board using CubeProgrammer.
However, the board shows a 0.0.0.0 version of FUS and Stack and I cannot start FUS.
I don't know why there is no version because the FUS cannot be deleted forever in the FUS upgrade document.
So, How can I update FUS in this version?
The SBRV option byte is 0x3ffff is it common?
4 REPLIES 4
STTwo-32
Hello @KKIM.6
According to the SBRV value, FUS is not running. I suggest you try to update your firmware Following this wiki and using the last version (included in the version 1.18.0 of the STM32CubeWB).
Best Regards.
STTwo-32
Could you send the link again?
I'm trying to upgrade FUS following the "STM32WB Firmware Upgrade Service wiki" but there is no description when FUS does not exist.
I couldn't solve this problem yet...
Remi QUINTIN
The SBRV value is pointing on the safeboot which means something went badly wrong during the update.
I assume the SFSA value to be FFFF protecting the last sector.
Did you already program this board?
I would be nice to get the ESE and SFSA values.
Then one thing that may work to recover your board in a manufactory state is to write the value 0x00008000 at the address 0x5800040C. This should work if ESE option byte is checked.
