Unable to start FUS. FUS version is 0.0.0.0 and FUS_STATE_ERR_UNKNOWN
‎2024-03-12 2:25 PM - edited ‎2024-03-12 2:34 PM
I'm trying to fix a P-Nucleo-WB55 board using CubeProgrammer.
However, the board shows a 0.0.0.0 version of FUS and Stack and I cannot start FUS.
I don't know why there is no version because the FUS cannot be deleted forever in the FUS upgrade document.
So, How can I update FUS in this version?
The SBRV option byte is 0x3ffff is it common?
STM32WB series
‎2024-03-13 2:30 AM - last edited on ‎2024-03-14 3:16 AM by VictorD
Hello @KKIM.6
According to the SBRV value, FUS is not running. I suggest you try to update your firmware Following this wiki and using the last version (included in the version 1.18.0 of the STM32CubeWB).
Best Regards.
STTwo-32
‎2024-03-13 9:36 AM
Could you send the link again?
I'm trying to upgrade FUS following the "STM32WB Firmware Upgrade Service wiki" but there is no description when FUS does not exist.
‎2024-03-19 6:36 PM
I couldn't solve this problem yet...
‎2024-04-12 10:08 AM
The SBRV value is pointing on the safeboot which means something went badly wrong during the update.
I assume the SFSA value to be FFFF protecting the last sector.
Did you already program this board?
I would be nice to get the ESE and SFSA values.
Then one thing that may work to recover your board in a manufactory state is to write the value 0x00008000 at the address 0x5800040C. This should work if ESE option byte is checked.
‎2025-02-24 12:16 AM
I encountered a similar issue where the FUS became unresponsive after sending an event signal. STM32CubeProgrammer now reports the FUS and wireless stack versions as v0.0.0.0.
I am unsure what caused this issue. Multiple recovery attempts, including updating the FUS firmware, did not work.
Were you able to fix the issue? How can I avoid this in the future? Any guidance would be appreciated.
Thanks!
‎2025-02-25 4:37 AM
Step by step guidance for restoring option bytes corruption as defined in AN5185, page 10.
- Connect MCU using Stlink USB and start STM32CubeProgrammer
- If there is problem to connect using STM32CubeProgrammer, add jumper to BOOT0 pin
1.set RDP AA (will remove the PCROP as well)
- Ensure PCROP and RDP is not active
2.set OB to boot in System Flash (nBoot0 = 0)
3.reboot
4.connect STM32CubeProgrammer with hotplug
5.start CPU2 using write 0x00008000 at 0x5800040C
