STM32WL LoRa and Sigfox in one application ?
JBE
Hi everyone,
I am currently working on the STM32WL55JC, I am using the stm32cubewl_v1-1-0 for doing a LoRa application and a Sigfox application using the provided examples.
I would like to know if there are any limitations (Hardware and/or software) for implementing an application which mixes the use at runtime of the 2 LPWAN commmunications (LoRa and Sigfox).
In term of memory consumption, I see that the application needs to be optimized to fit in. But do you have any other ones ?
Has someone already tried it ?
thank you in advance.
Best regards
1 REPLY 1
LLr.1
It is an interesting project! Did you succeed or did you encounter difficulties?
Thank you for your reply
Louis
