LoRa Option in STM32 Cube for bl072cz-lrwan1
sgabran
Hi
I am trying to create SubGHz project using STM32 Cube. When I choose the bl072cz-lrwan1 board, although this is an eval kit for LoRa, and has a PingPong example which uses LoRa and SubGHz, yet I can't find any option for SubGHz or LoRa in the middleware menu.
any suggestions what to do ?
thanks
3 REPLIES 3
IIRHO.1
Hello @sgabran and welcome to ST Community
Which CubeMX version are you using?
I tested the case from my side and it works for me using STM32CubeMX 6.8.0 .
I hope this is helpful for you. Please make sure to use the lastest release of CubeMX.
sgabran
Hi
Thanks, I downloaded the latest CubeMX, i found the X-CUBE-SUBG2, but I am not sure which option to choose that is compatible with the bl072cz-lrwan1 board. Would you be able to help me out choose the appropriate pingpong application for that board please ?
thanks
IIRHO.1
Hello again @sgabran.
I suggest you to verify  your board extension reference and choose the compatible P2P example.
Issam.
