LoRa-E5 mini (STM32WLE5JC) programming using STM32CubeIDE
FBrin.1
I am using LoRa-E5 mini board from seeed studio (https://www.seeedstudio.com/LoRa-E5-mini-STM32WLE5JC-p-4869.html)
To program it using STM32CubeIDE, do we need to connect it to pc using ST-Link or we can simply program it via Type C cable?
13 REPLIES 13
This above example is for LoRa-E5 which uses the STM32WLE5J. You will need to replace the LoRa-LoRaWAN-End-Node folder with this LoRa-E5-LoRaWAN-End-Node in Nucleo to make it work for STM32WLE5J8. Also, you should read this first - https://github.com/seeed-lora/LoRa-E5-LoRaWAN-End-Node , it explains everything nicely.
The github link is broken .
It says page not found.
Is there any other link
Strooom
Can you please give us an updated link to a github repository. The link above does no longer work.
