LoRa-E5 mini (STM32WLE5JC) programming using STM32CubeIDE
‎2021-06-11 6:13 AM
I am using LoRa-E5 mini board from seeed studio (https://www.seeedstudio.com/LoRa-E5-mini-STM32WLE5JC-p-4869.html)
To program it using STM32CubeIDE, do we need to connect it to pc using ST-Link or we can simply program it via Type C cable?
LoRa
STM32CubeIDE
STM32WL series
‎2021-06-18 1:20 AM
This above example is for LoRa-E5 which uses the STM32WLE5J. You will need to replace the LoRa-LoRaWAN-End-Node folder with this LoRa-E5-LoRaWAN-End-Node in Nucleo to make it work for STM32WLE5J8. Also, you should read this first - https://github.com/seeed-lora/LoRa-E5-LoRaWAN-End-Node , it explains everything nicely.
‎2021-12-18 6:57 AM
The github link is broken .
It says page not found.
Is there any other link
‎2021-12-28 9:50 PM
‎2022-11-23 3:50 AM
Can you please give us an updated link to a github repository. The link above does no longer work.
- « Previous
- 1
- 2
- Next »
