2022-04-21 08:55 AM
2022-04-21 11:50 PM
2022-04-21 09:02 AM
That would depend on if other code sets the pin high, assuming that will power a TCXO, then you're basically shorting that to ground, pulling maximal current through the transistor. Doesn't seem like a good plan to me.
2022-04-21 11:50 PM
you can simply use it as any GPIO (PB0)
2022-04-26 04:39 AM
Okay! Thanks both for the reply.
