how to set RF SW CTRL pins?
SSaya.1
Hello, How to set RF SW CTRL pins? How to make them appear in platform settings of SUBGHZ_PHY configuration?0693W00000FAJMGQA5.jpg
FRest.1
anyway they are controlled by BSP drivers
This is part of the drivers:
int32_t BSP_RADIO_ConfigRFSwitch(BSP_RADIO_Switch_TypeDef Config)
  switch (Config)
    case RADIO_SWITCH_OFF:
      /* Turn off switch */
      HAL_GPIO_WritePin(RF_SW_CTRL3_GPIO_PORT, RF_SW_CTRL3_PIN, GPIO_PIN_RESET);
      HAL_GPIO_WritePin(RF_SW_CTRL1_GPIO_PORT, RF_SW_CTRL1_PIN, GPIO_PIN_RESET);
      HAL_GPIO_WritePin(RF_SW_CTRL2_GPIO_PORT, RF_SW_CTRL2_PIN, GPIO_PIN_RESET);
      break;
2 REPLIES 2
FRest.1
I think you should use the related API
0693W00000FAK1JQAX.pngas described on AN5406
F.
FRest.1
  switch (Config)
      break;
