2024-04-09 09:35 AM - edited 2024-04-09 10:02 AM
How to manually download submodules manually and put them in correct directory structure, for use with Nucleo-WL55JC1 (8xx/9xx MHz)?
In https://github.com/STMicroelectronics/STM32CubeWL, when I used the Green "code" button to download zip, some directory are empty and failed to locate .c and .h files on build. TIA
2024-04-09 09:46 AM - edited 2024-04-09 09:47 AM
If you can't unzip them to the right nodes, perhaps unpack to a sandbox, and use your file manager of choice to move or drag-n-drop into the right directory nodes?
Perhaps GitHub for Desktop facilitates this in a more manageable/automated way?
2024-04-09 12:44 PM
2024-04-09 12:46 PM
Thanks. Yes, it should be possible. Seem the dir structure is very different. May be due to different WL lib and also single vs dual core MCU.
2024-04-09 03:26 PM
