How to manually download submodules manually?
David_
How to manually download submodules manually and put them in correct directory structure, for use with Nucleo-WL55JC1 (8xx/9xx MHz)?
In https://github.com/STMicroelectronics/STM32CubeWL, when I used the Green "code" button to download zip, some directory are empty and failed to locate .c and .h files on build.  TIA
If you can't unzip them to the right nodes, perhaps unpack to a sandbox, and use your file manager of choice to move or drag-n-drop into the right directory nodes?
Perhaps GitHub for Desktop facilitates this in a more manageable/automated way?
4 REPLIES 4
mÆŽALLEm
Simply download the Cube package from here.
Or use git tool to download the full pack using recursive option. See this thread.
Thanks.  Yes, it should be possible.  Seem the dir structure is very different.  May be due to different WL lib  and also single vs dual core MCU.
