Error: Rollback to older version of FW detected and not allowed! + upgrade steos
‎2024-01-22 8:09 PM
I am trying to perform a firmware upgrade but I keep receiving an error message Error: Rollback to older version of FW detected and not allowed!
Is there a way to get around this error? I have added a photo of the stm programmer page.
Additionally - can someone please confirm the order of performing an update? Should it be as follows?
Upgrade with stm32wb5x_FUS_fw_for_fus_0_5_3.bin
Upgrade with stm32wb5x_FUS_fw.bin
Upgrade with (in my case): stm32wb5x_BLE_Stack_full_fw.bin
Can I just jump to upgrading with stm32wb5x_BLE_Stack_full_fw.bin without the previous two? Thanks a lot as this is really quite the challenge for me currently.
BLE
Bug-report
STM32WB series
Wifi
‎2024-01-23 10:30 PM
In this case the stack reference version is considered as 0xFFFFFFFF (while no stack installed and anti-rollback is activated), so no firmware update is allowed after that, and no recovery is possible at this point.
Best Regards.
STTwo-32
‎2024-01-23 1:58 AM
Hello @od805
I think you have activated the Anti-rollback without ensuring that a wireless stack is correctly installed. If so, the FUS registers 0xFFFFFFFF as the new version, and it is not possible to install a wireless stack. For more details about Anti-rollback activation, I suggest you take a look at the part 2.4 of the AN5185.
Best Regards.
STTwo-32
‎2024-01-23 2:04 AM
On this wiki page STM32WB_FUS , you will find a detailed manual about the FUS (4/ FUS activation and upgrade):
Can you test if this resolves your problem?
If not, don't hesitate to come back to me and let me know where you are stuck.
BR, Joé.
‎2024-01-23 2:11 PM
So if this is the case is this board no longer usable?
Best Regards.
STTwo-32
‎2024-01-24 12:26 PM
OK Thanks for that.
Trying to work on a new board and running into this error when installing stm32wb5x_FUS_fw_for_fus_0_5_3.bin
I know the documents may outline how to navigate this but I would greatly appreciate how to fix this error from experts instead of reading the documents(s).
Please advise.
‎2024-01-25 6:13 AM
If the original FW version, is not the 0.5.3, then you have to use directly the stm32wb5x_FUS_fw.bin. Try a full chip erase. Then, try firmware upgrade using the stm32wb5x_FUS_fw.bin and following this Wiki.
Best Regards.
STTwo-32
‎2024-01-28 1:14 PM
Hi again,
I tried doing the following:
Install stm32wb5x_FUS_fw.bin.
Install stm32wb5x_BLE_Stack_full_fw.bin
I am wondering why my custom BLE_HeartRate code in STMIDe does not work when I upload to the MCU?
The original BLE_HeartRate code works as well as BLE_BloodPressure. My code is using a blend of BLE_HeartRate and BLE_Sensor (from discovery kit) because of BLE_Sensor's P2P capabilities.
I think primarily the issue is the BLE_Sensor example does not work. Why is this??? Again, BLE_BloodPressure and HeartRate does work...
This is not the case for my other previously flashed boards. I am using a STM32WB5MMGH6TR (same MCU associated with DK) MCU on my custom PCB. Please advise as I am quite confused on the matter...
‎2024-01-28 1:42 PM
Hello
I suggest you to close this post since the original question is answered. And open a new post with a full description of the new request.
Best Regards.
STTwo-32
