DFU Firmware lost
cloud_liu
My MCU is STM32F746ZG. When I want to use DFU to upgrade my board by STM32CubeProgrammer, It show "No DFU detected" in the port list. And I use "zadig" to try install DUF driver, it cannot find any STM DUF device, too.
Do my DFU firmware lost in my MCU? If can I download DFU firmware to program it by ST-Link?
Cloud
Please contact maker of this board (or their community) - they will be glad to help. According to the board image, it has a USB connector. Maybe need to put some jumper etc.
4 REPLIES 4
Pavel A.
The "system bootloader" implements DFU, it cannot get lost and you don't need to program it.
Just connect the USB pins of the board correctly and use a good USB cable. If the board is not visible on Windows side in the device manager (even as unknown device) - you've failed to connect it correctly. Try again.
Ok, I will contact the maker, thanks for help.
