2025-03-26 4:18 PM - last edited on 2025-03-27 1:36 AM by STTwo-32
When "Middleware and Software Packs" > STM32_WPAN is enabled in CubeMX, a duplicated initialization's code for uwTimclock is generated:
That code is outside the if-else block overriding the previous configurations which could produce issues.
Note: I attached the .ioc file.
Details:
2025-03-27 2:05 AM - edited 2025-03-27 5:45 AM
Hello @mpc and welcome to the ST Community.
I've been able to reproduce this behavior, and I've reported internally for correction on the Future (under internal ticket number 206323). Thank you so much for your contribution.
Best Regards.
STTwo-32
Best Regards.
STTwo-32
2025-03-27 3:56 PM
I will be pending of new releases versions. Thank you .
