Translations.rb never finishes
manto.1
I want to export texts.xml to .xlsx with running the following comand
ruby translations.rb export texts.xml texts.xlsx
the problem is that it never finishes I left it running more than 30 minutes. Text.xml was generated by TouchGFX 4.21.2.
This was working in version 4.20.0.
Can someone please try to convert the text.xml included below.
3 REPLIES 3
Yoann KLEIN
Hello @manto.1​,
Did you forget to attach the file ?
We would like to try it on our side.
/Yoann
Yoann KLEIN
manto.1
I am sorry, it works alright now. I did not run the .bat file the right way.
However afer importing back the texts.xml in TouchGFX designer In Texts section a strange rectangle apears in one section. (Just as an observation)
Yoann KLEIN
What happens if you use TouchGFX 4.21.4 ? Still see the same rectangle ?
/Yoann
Yoann KLEIN
