TouchGFX Code generating error
HCheo.1
TouchFGX Ver : 4.15.0
Target Board : STM32f7508 Discovery
At startup and when I pressed "Run Target" or "Generate Code" the program shows:
3 REPLIES 3
HCheo.1
  Compile
    make -f simulator/gcc/Makefile -j8
    Reading ./application.config
    Compiling gui/src/main_screen/MainPresenter.cpp
    Compiling gui/src/main_screen/MainView.cpp
    Compiling gui/src/model/Model.cpp
    Compiling gui/src/common/FrontendApplication.cpp
    Compiling generated/gui_generated/src/main_screen/MainViewBase.cpp
    Compiling generated/gui_generated/src/common/FrontendApplicationBase.cpp
       0 [main] us 0 init_cheap: VirtualAlloc pointer is null, Win32 error 487
    AllocationBase 0x0, BaseAddress 0x60EA0000, RegionSize 0x160000, State 0x10000
    E:\TouchGFX\4.15.0\env\MinGW\msys\1.0\bin\mkdir.exe: *** Couldn't reserve space for cygwin's heap, Win32 error 0
    generated/simulator/gcc/Makefile:190: recipe for target 'build/MINGW32_NT-6.2/gui/src/main_screen/MainPresenter.o' failed
    Compiling generated/simulator/src/mainBase.cpp
    make[2]: *** [build/MINGW32_NT-6.2/gui/src/main_screen/MainPresenter.o] Error 1
    make[2]: *** Waiting for unfinished jobs....
    Compiling generated/fonts/src/GeneratedFont.cpp
    generated/simulator/gcc/Makefile:190: recipe for target 'build/MINGW32_NT-6.2/gui/src/main_screen/MainView.o' failed
    make[2]: *** [build/MINGW32_NT-6.2/gui/src/main_screen/MainView.o] Error 1
    generated/simulator/gcc/Makefile:190: recipe for target 'build/MINGW32_NT-6.2/gui/src/model/Model.o' failed
    make[2]: *** [build/MINGW32_NT-6.2/gui/src/model/Model.o] Error 1
    generated/simulator/gcc/Makefile:190: recipe for target 'build/MINGW32_NT-6.2/gui/src/common/FrontendApplication.o' failed
    make[2]: *** [build/MINGW32_NT-6.2/gui/src/common/FrontendApplication.o] Error 1
    generated/simulator/gcc/Makefile:190: recipe for target 'build/MINGW32_NT-6.2/generated/gui_generated/src/main_screen/MainViewBase.o' failed
    make[2]: *** [build/MINGW32_NT-6.2/generated/gui_generated/src/main_screen/MainViewBase.o] Error 1
    generated/simulator/gcc/Makefile:190: recipe for target 'build/MINGW32_NT-6.2/generated/gui_generated/src/common/FrontendApplicationBase.o' failed
    make[2]: *** [build/MINGW32_NT-6.2/generated/gui_generated/src/common/FrontendApplicationBase.o] Error 1
    generated/simulator/gcc/Makefile:190: recipe for target 'build/MINGW32_NT-6.2/generated/simulator/src/mainBase.o' failed
    make[2]: *** [build/MINGW32_NT-6.2/generated/simulator/src/mainBase.o] Error 1
    generated/simulator/gcc/Makefile:190: recipe for target 'build/MINGW32_NT-6.2/generated/fonts/src/GeneratedFont.o' failed
    make[2]: *** [build/MINGW32_NT-6.2/generated/fonts/src/GeneratedFont.o] Error 1
    generated/simulator/gcc/Makefile:149: recipe for target 'generate_assets' failed
    make[1]: *** [generate_assets] Error 2
    simulator/gcc/Makefile:32: recipe for target 'all' failed
    make: *** [all] Error 2
    Failed
HCheo.1
The same problem occurs even if the program is reinstalled after Uninstalled.
Martin KJELDSEN
Chief III
Hi, this is a problem with msys.dll - You most likely have multiple ones on your path (TouchGFX Envs being one of them).
It's a common problem out there in the real world and the solution seems to be to "rebase" the dll. Can you try searching for that solution and get back to me?
