TouchGFX Code generating error..
HCheo.1
I asked a question about "TouchGFX Code generating error" last time,
but I haven't solved it yet,
Soi I posted it again.
https://community.st.com/s/question/0D53W00000KofEVSAZ/touchgfx-code-generating-error
Martin KJELDSEN
Chief III
(Copied from my reply to the other post)
Hi, this is a problem with msys.dll - You most likely have multiple ones on your path (TouchGFX Envs being one of them).
It's a common problem out there in the real world and the solution seems to be to "rebase" the dll. Can you try searching for that solution and get back to me?
