Text Rotation in touchgfx 4.13 Creates problem in STM32H750VB
RG.3
In touchgfx software....0693W000005ARaLQAW.pngIn Display Board......0693W000005ARgTQAW.jpg
Is there is any way so that I can fix it....?
ok...
void MPU_Config(void)
  MPU_Region_InitTypeDef MPU_InitStruct = {0};
  /* Disables the MPU */
  HAL_MPU_Disable();
  /** Initializes and configures the Region and the memory to be protected
  MPU_InitStruct.Enable = MPU_REGION_ENABLE;
  MPU_InitStruct.Number = MPU_REGION_NUMBER0;
  MPU_InitStruct.BaseAddress = 0x24000000;
  MPU_InitStruct.Size = MPU_REGION_SIZE_512KB;
  MPU_InitStruct.SubRegionDisable = 0x0;
  MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
  MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;
  MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_DISABLE;
  MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE;
  MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE;
  MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
  HAL_MPU_ConfigRegion(&MPU_InitStruct);
  MPU_InitStruct.Number = MPU_REGION_NUMBER1;
  MPU_InitStruct.BaseAddress = 0x90000000;
  MPU_InitStruct.Size = MPU_REGION_SIZE_256MB;
  MPU_InitStruct.AccessPermission = MPU_REGION_NO_ACCESS;
  MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE;
  MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE;
  MPU_InitStruct.Number = MPU_REGION_NUMBER2;
  MPU_InitStruct.Size = MPU_REGION_SIZE_128MB;
  MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE;
  MPU_InitStruct.Number = MPU_REGION_NUMBER3;
  MPU_InitStruct.BaseAddress = 0xD0000000;
  MPU_InitStruct.Number = MPU_REGION_NUMBER4;
  MPU_InitStruct.Size = MPU_REGION_SIZE_32MB;
  /* Enables the MPU */
  HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
4 REPLIES 4
Alexandre RENOUX
Principal
Here is some suggestions you can look into :
  • Update to TouchGFX 4.15
  • Try with an ST board (STM32H750-DISCO) to see if you have the same problem
  • If you use external Flash and your fonts&Texts are in external Flash, try putting them in internal Flash.
  • If you use external Flash, check that your external Flash is correctly set.
Also, please give more information on your setup.
/Alexandre
RG.3
Greetings,
My problem got solved by changing the MPU_Config() from main.cpp. Thanks for your Support.
Rishikesh G
Alexandre RENOUX
Principal
When your question is answered, please close this topic by choosing Select as Best.
Could you share your new MPU_Config that fixed your issue ? This can help others as well.
/Alexandre
ok...
  HAL_MPU_Disable();
