Text Rotation in touchgfx 4.13 Creates problem in STM32H750VB
‎2020-11-05 2:28 AM
In touchgfx software....In Display Board......
Is there is any way so that I can fix it....?
- Labels:
TouchGFX
‎2020-11-08 10:45 PM
ok...
void MPU_Config(void)
MPU_Region_InitTypeDef MPU_InitStruct = {0};
/* Disables the MPU */
HAL_MPU_Disable();
/** Initializes and configures the Region and the memory to be protected
MPU_InitStruct.Enable = MPU_REGION_ENABLE;
MPU_InitStruct.Number = MPU_REGION_NUMBER0;
MPU_InitStruct.BaseAddress = 0x24000000;
MPU_InitStruct.Size = MPU_REGION_SIZE_512KB;
MPU_InitStruct.SubRegionDisable = 0x0;
MPU_InitStruct.TypeExtField = MPU_TEX_LEVEL0;
MPU_InitStruct.AccessPermission = MPU_REGION_FULL_ACCESS;
MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_DISABLE;
MPU_InitStruct.IsShareable = MPU_ACCESS_NOT_SHAREABLE;
MPU_InitStruct.IsCacheable = MPU_ACCESS_NOT_CACHEABLE;
MPU_InitStruct.IsBufferable = MPU_ACCESS_NOT_BUFFERABLE;
HAL_MPU_ConfigRegion(&MPU_InitStruct);
MPU_InitStruct.Number = MPU_REGION_NUMBER1;
MPU_InitStruct.BaseAddress = 0x90000000;
MPU_InitStruct.Size = MPU_REGION_SIZE_256MB;
MPU_InitStruct.AccessPermission = MPU_REGION_NO_ACCESS;
MPU_InitStruct.IsCacheable = MPU_ACCESS_CACHEABLE;
MPU_InitStruct.IsBufferable = MPU_ACCESS_BUFFERABLE;
MPU_InitStruct.Number = MPU_REGION_NUMBER2;
MPU_InitStruct.Size = MPU_REGION_SIZE_128MB;
MPU_InitStruct.DisableExec = MPU_INSTRUCTION_ACCESS_ENABLE;
MPU_InitStruct.Number = MPU_REGION_NUMBER3;
MPU_InitStruct.BaseAddress = 0xD0000000;
MPU_InitStruct.Number = MPU_REGION_NUMBER4;
MPU_InitStruct.Size = MPU_REGION_SIZE_32MB;
/* Enables the MPU */
HAL_MPU_Enable(MPU_PRIVILEGED_DEFAULT);
‎2020-11-08 9:44 PM
Here is some suggestions you can look into :
- Update to TouchGFX 4.15
- Try with an ST board (STM32H750-DISCO) to see if you have the same problem
- If you use external Flash and your fonts&Texts are in external Flash, try putting them in internal Flash.
- If you use external Flash, check that your external Flash is correctly set.
Also, please give more information on your setup.
/Alexandre
‎2020-11-08 10:03 PM
Greetings,
My problem got solved by changing the MPU_Config() from main.cpp. Thanks for your Support.
Rishikesh G
‎2020-11-08 10:08 PM
When your question is answered, please close this topic by choosing Select as Best.
Could you share your new MPU_Config that fixed your issue ? This can help others as well.
/Alexandre
ok...
HAL_MPU_Disable();
