2024-03-18 05:10 AM - edited 2024-03-18 05:23 AM
I have TouchGFX Designer 4.22.0 version installed in my PC. For my project I am using STM32U5A9NJH6Q controller with Riverdi display part number SM-RVT50HQSNWC00-B. But, in the TouchGFX Designer application I am not able to create a project because in create->By Partners i am not able to find a template for this particular display. I can only find the templae for 1280*800 and 1024*600 resolution displays for Riverdi. But not for 800*480 resolution.
Can any one please have a look in this and help me fix this issue. I have also attached in the screenshot of how my designer application create window looks.
2024-03-18 07:18 AM
Hello @Sgowd.1 ,
Is your board correctly powered? Can you access it with an external ST-LINK?
You can follow this tutorial to check the pins connection and generate your project for a Riverdi display board.
Can you try with latest release of TouchGFX Designer 4.23.2?
2024-03-18 07:18 AM
Hello @Sgowd.1 ,
2024-03-18 07:24 AM
Hello @Imen.D
Yes, the board was powered on. But the issue is fixed in the latest version 4.23.2.
Sachin
