2024-11-18 12:50 PM
I was trying to use TouchGFX for the RVA35HI display with the U575ZI-Q development board. In the product website it does say that there will be a demo project for the same. I am using TouchGFX Designer version 4.24.1 and am unable to find it.
It would be of great help if I was given some information regarding the demo code or guided towards how I can actually design a GUI using TouchGFX for the above mentioned configuration. Thanks in advance!
2024-11-28 8:06 AM
Hello @CharanVis ,
The TBS (TouchGFX Board Setup) for the STM32U575+RVA35HI is available in TouchGFX Designer 4.24.0 and newer.
Sorry for the inconvenience.
2024-11-19 6:28 AM
Hello @CharanVis ,
This thread is a duplicate of this one.
The demo project is indeed not available yet, but it will soon be released.
I'll let you know as soon as I have more info about it :)
2024-11-19 10:52 AM
Hello @Osman SOYKURT ,
Thank you for your quick response. Just a suggestion: it would be great if that can be updated on the website where it says that the demo project is available for the U575 dev board.
Meanwhile, I will wait for updates on the demo :)
Thanks again!
2024-11-19 12:03 PM - edited 2024-11-19 12:06 PM
Hi Osman,
Why is it advertised by ST that a demo project is available, if neither ST or Riverdi actually have it available?! We purchased this board around two months ago because of that statement... and only now, as we start to use it has it been uncovered that ST has not yet released this.
This unfortunate publication of incorrect information has stalled our project.
When will the U575 demo be available please? Again, this is advertised as already being available - and as such became the focus of our development efforts.
@Osman SOYKURT - Can you please remove the "solved" status of this ticket. This should not be marked as solved until either the incorrect website material has been removed, or until the demo is made available as advertised.
Thank you
Darcy
2024-11-20 2:14 AM
Hello @DarcyW ,
I understand your frustration and we apologize for the delay. Our team is currently putting all our efforts into publishing the example project as soon as possible. We expect it to be available shortly.
I will ensure that future publications contain accurate information to prevent such issues.
I agree that my answer shouldn't be marked as solution, so I'm removing it if @CharanVis agrees (since he marked the answer as solution).
Thank you for your patience and understanding.
2024-11-20 11:16 AM
Hi @Osman SOYKURT , I agree that it shouldn't be marked as a solution. You can have it removed
2024-11-28 8:06 AM
Hello @CharanVis ,
